4 blade vs 3 blade prop
slake
I am purchasing a 90hp Honda and the dealer suggested a 4 blade prop instead of of a 3 blade for pulling tubers etc... it will be going onto a pontoon boat. Is this the right call? not sure of the pitch.
D
DJ
Guest
Re: 4 blade vs 3 blade prop
slake,<br /><br />The four blade prop. typically provides a better bite on the water and tends to hold better-less possibility of cavitation. That is important on a toon.<br /><br />The most important thing is that the pitch is low enough to allow the engine to reach its full operating rpm.
slake
djohns19,<br /><br />Thanks, for the info on the pitch.. I did not know anything about proper pitch. so I take it the lower the pitch allows the engine to turn easier in the water for more rpm?
D
DJ
Guest
slake,<br /><br />You are correct. A general rule is that each inch in pitch equals about 200 rpm-up or down.
