4 blade prop?
FTB530
I have a Johnson 2 stroke 15 hp outboard and i am thinking about changing the prop.(this one is a little banged up) i saw one with four blades, is there an advantage with the 4 blade or should i just stick to the oem 3 blade type that is on it now ?thanks for any feedback.
Re: 4 blade prop?
IMO a 4 blade prop on a 15 HP would slow you down due to the added drag of the extra blade. 4 blade props are useful with bigger engines where they provide extra prop blade surface area, probably not gonna' do you any good (except for making your wallet lighter).
FTB530
Re: 4 blade prop?
Thank you , i think i will stick with the three bladed prop!
fishrdan
Re: 4 blade prop?
What are you using the 15HP outboard for?
Not that I'm any expert on small OB props, but most of the 4 blade props I've seen for small OB's are low pitch props, power props used for kicker motors or pushing heavy loads.
Do you have a link to the 4 blade prop you're looking at.
FTB530
Re: 4 blade prop?
No link, i was just looking on Amazon and e bay at them,not using it for a kicker , just for all around use,going to get a three blade prop.
Starcraft5834
Re: 4 blade prop?
4 blades for heavy hulled boats. Or water sports. .stay w 3 blade
pecheux
Re: 4 blade prop?
I read on IBoat that it is recommended to reduce pitch 1 inch when going from 3 blades to 4.
dazk14
Ensign
Re: 4 blade prop?
You don't give ant specs on top speed, etc.. or what you are trying to improve.
A Solas from iboats will give great value.
The stainless Saturn gives max performance. drop pitch an inch - it's cupped.
