I have a 19.5' bowrider with a merc 5.0l and alpha 1 drive, currently have a 14.5x19 3 blade prop, I want to switch over to a new 4 blade prop. Currently I get about 42mph @ 4500rpm trimmed out. I understand that when switching to a 4 blade you usually step down 1" in pitch to maintain the same rpm. However, 18p 4 blade props are not common. So either I stay with a 19p 4 blade and take the assumed 200rpm drop or step down to a 17p prop and jump up 200rpm @WOT. I don't ever run at WOT so there isn't a concern about over revving the motor. I spend most of the time cruising or towing (mostly tubes). I have only had the boat a few months now and this is going to be my first prop change, so any suggestions would be appreciated.
