Hi all,
I recently had a 90' campion allante 185 w/ 4.3LX mercruiser motor inspected.
The inspector found the following issues.
Charging system seems to be running at about 11.5v at idle and drops to a little above 10volts when trottling up to 2000rpm. He figures it will need a new alternator or batteries. Im looking for clarification on this.
Also, these are the specs he got from idling the engine...
Warm engine
40psi oil pressure
temp 130 degrees
800rpm at idle
Im looking for what people can tell me on the charging system, how easy is it to do, what the actual issue may be and what parts might need replacing.
Id also like to see if the engine specs at warm idle sound good.
Chris,
Warm engine
40psi oil pressure
temp 130 degrees
800rpm at idle
Chris,
