Hi, <br /><br />I'm a new boat owner with a 1996 20.5' SeaSwirl, the engine is a 4.3L (GM) 1996 Volvo Penta GL with a OMC outdrive (SX). Don't know a whole lot about the previous history of the boat, seems mostly well taken care of, but there are hints that some problems existed when it was sold. <br /><br />I've taken it out a couple of times. On the first trip, I noticed that the temperature guage never came off the low peg (a bit below 120F). Verified the operation of the gauge (100 ohms = 160F) and the sender (hot water bath). Took the thermostat out and found a collection of chunks of stuff jammed into it.<br /><br />What I found in the thermostat was one piece of torn roundish plastic (might be a water pump vane, don't know). I also found hard light brown rock like pieces about 1/8" by 1/4" squarish piece.<br /><br />I replaced the thermotat. Took the boat out and as I idled away from the dock and into the nowake zones, the temperature came up to 160F and held. As soon as I opened it up, and started running at about 3000 rpm, the temperature fell back to 120F. Temperature stayed that way for the next 3 hours, saw one slow rise to 130 when I was slowed for a bit.<br /><br />The engine starts/run fine. Pulls nicely at speed. Idle seems 'cold' (not too surprising). Gets a little blue smoke smell at idle. No real oil consumption. (I'm assuming that the little bit of oil smell that I'm getting at idle is a cold engine issue).<br /><br />I haven't opened up the thermostat (yet), but I'm guessing that I've got the same problem. <br /><br />When I had the thermostat housing off previously, the interior of the passages had a little surface rust (it had been winterized prior to this), but nothing that looked too bad.<br /><br />The only thing that I can think of is that the previous owner got into some sand/gravel and sucked it into the cooling system. Seems like there ought to be a screen somewhere.<br /><br />The piece of plastic worries me a bit. I've heard that the impellers in the outdrive unit is something that I should do, just as a matter of course. <br /><br />Assuming that the source of the problem is gravel injestion, how would I go about flushing this out of the block? I should mention that when I drained the block, I didn't get anything other than water, other than an initial pulse of rusty colored water. No chunks, sand, etc.<br /><br />Any advice, thoughts, warnings for a new boat owner?<br /><br />Thanks,<br /><br /> johnbo
