4.3L mercruiser alpha 1 loud screaching noise
BlueVIP
1993 Monterey with a 4.3L merc alpha 1. Boat starts and seems to run fine. After running it for a little while then sitting with it turned off for a little bit. When I start it again it will make a loud screaching noise sounds like belts to me but not sure. Read somewhere online it could be alternator bearing or Gimbal bearing. I thought the gimbal bearing made a growling noise? Any help would be appreciated.
alldodge
Yes gimbal growls, Alt bearing or belt squeals
Remove the belt a feel the bearings spinning each pulley
BlueVIP
Had my mechanic change oil today and he tightened up the belts. How tight should the belts be? Thanks
depends if its a multi-vee (serpentine) or a traditional v-belt. if a v-belt, the specific series has a spec
vetting
How long does the noise last when you start it up? Its it worse when its damp out?
BlueVIP
It lasts maybe 30 seconds. It has quit now with the belts being tightened up. It tried to do it yesterday after running it while pulling the kids on the tube.
