Gaetan Carrier
- Aug 30, 2010
- 8
Just installed factory exhaust manifold on port side to get dry-joint back to original setup, previous owner had installed after market manifold and it was leaking. The riser looked ok so re-installed with new manifold. Removed hoses leading to risers while engine was at idle and same amount of water (not much) seems to be going to each riser but haven't checked hoses leading to manifolds.
The port side is much warmer and really can't leave your hand on it too long. The temperature gauge seems to run 160-175 degrees. The engine was already running hot before the new manifold. I believe the gaskets were installed correctly with the restrictor tab going between spacer and riser, in the front by the inlet hose.
Outdrive impeller may need replacing but one side of engine seems fine. Wondering if I have clogged passages in the block/head or obstructions in the riser or exhaust?
The engine is a 2004 vintage with original everything except the new manifold.
