Re: 4.3L GL Water in the oil
I would order a new intake manifold, drain water/oil mix trhrough oil pan drain at dipstick fitting, remove all spark plugs, crank engine to expel water from cylinders, spray fogger in cylinders, clean all spark plugs, clean/flush the engine thoroughly (shop vac with small hose will help), inspect block for visible cracks (especially around the lifter housings), install intake manifold, let RTV set up for 24-hrs, install fresh oil and filter (add half pint of seafoam to oil), put water muffs on and crank engine. Let it run for awhile to heat the oil up good, then drain oil at oil dipstick fitting on oil pan. Remove the newly installed oil filter and dump oil/water mix out. Reinstall same oil filter, fill with fresh oil and seafoam again, run engine on muffs until warmed up good and repeat. Should be pretty much cleared after that. Refill with proper oil and install a brand new oil filter. Also, if carburetted, clear PCV line to carb base and PCV valve itself. Clean flame arrestor as well. Then take it for a run on the lake. I would suggest stopping after a short run, checking the dipstick to see if it is clear, and also looking for any leaks. If you go this route, follow the instructions in your service manual. I simply repeated basically what I did when the same thing happened to me. Best of luck, and let us know how it all turns out. By the way: michiganmotorz.com had the best deal on intake manifolds I could find. And their shipping/packing was top notch.
