I have a volvo 4.3 GXi, he are having an issue with it not starting.
We have good crank, we have spark to the spark plugs and we have the correct fuel pressure in the fuel rails, and there seems to be no problem with the air intake.
We have noticed that after cranking with no start up the plugs should be wet with fuel if it was not starting. So have had determined that it must be something with the fuel injectors, or the ECM.
Does any one know how to test to see if the ECM is sending the signal to the injector to open and send fuel to the cylinders?
the engine SN is 3869252
