4.3 V 6 engine Running on 3 cylinders ONLY
eshelon
just put new valves in heads and left side which 2.4.6 cylinders not running
Engine running rough on 3 cylinders
so i checked the plugs and spark OK
Compression 120
carburetor and Fuel OK
ignition timing OK
Any ideas what else can be causing this problem ?
Re: 4.3 V 6 engine Running on 3 cylinders ONLY
Compression 120
ignition timing OK
Ayuh,... Welcome Aboard,... My guess is,...
The opposite side of yer Carb, is Plugged solid,...
bruceb58
Unplug your ESA to see if it is causing your problem.
SeaTea
Double check your plug wires, make sure they go to the proper plugs. I know it sounds basic but you should make sure the basics are sound before you go chasing zebras.
About the zebras, I heard a story that people right out of med school look for exotic diseases for symptoms because they are way more sexy than a common cold. So when a normal person hears hoofbeats, he thinks horses but recent med school grads think zebras.
Don't go looking for zebras until all the horses are accounted for.
