stormrider
- May 20, 2009
- 17
Hey fellas! I need a little help. I bought a 1992 Mariah MX19 w/ a 4.3 Merc. Long story short, after replacing the engine due to cracks in block/heads, I have had a starting problem. The starter seems to drag when it's cold. I can hit the key several times and it eventually will start (most of the time). The funny thing is, it does it mostly after a run and it has had time to cool down..sarts great when it's hot. Here's a list of things that I have done:
Replaced starter
Replaced dual battery switch (even eliminated it & wired a single battery up)
Charged & load tested both batteries--good
Checked & cleaned all battery cables
Moved the ground location from bell housing to the starter
Battery cables look fine, even just behind the terminals where they usually corrode. I am at a loss.. but I have a "gut" feeling that water may be coming into the cylinder via the exhaust manifolds--will ck that tonight..any other suggestions would be appreciated.
Replaced starter
