Chain_skipper
- Apr 4, 2017
- 11
Hello,
Engine is a Mercruiser 4.3L V6, model year 1990 I believe. (S/N 0C665406)
Alpha One drive (S/N 0C684712)
Background information - The last time that I had her out the previous summer I was running near WOT. I trimmed the drive up a little too far, and the engine speed went about 3-400 RPM above the top of the range. Shortly after the engine had a knocking sound coming from the front, so I took it back to shore and then home.
That was the last run of the year, so I began to winterize it. I tried to troubleshoot the noise before I put away, so I changed the oil and filter, and started it on the muffs. The noise was not very audible at idle, but distinct around 2-2500 RPM, coming from around the harmonic balancer and water pump area. Took off accessory belts and ran briefly, the noise was still there. I then removed the pulley and ran briefly, and the noise went away. I then put the boat in storage for the winter.
After doing a bit of research, I found that a bad harmonic balancer can sound a lot like a rod knock. So I purchased a new one this summer and installed it. I started it this week and the noise is still present, and now sounds worse. I can hear the knock at idle up to around 2500, I don't want to go higher on the hose.
Can anybody suggest troubleshooting procedures or advice? I have so far not been able to come to a definitive conclusion, and I don't want to just throw money at it.
Thanks in advance
Thanks in advance
