mysearay185
- Sep 5, 2017
- 2
I have a 1997 searay with a 4.3lx and am trying to diagnose the cause of a nonstart issue. It will sporadically not turn over after being turned off - no reposnse when ignition is turned- totally dead. If the 10amp fuse is pulled and replaced or if the same fuse is put back, it starts right up. Only happens after it is run for awhile. ignition has been replaced but the problem continues. Even less frequently - the engine power drops momentrily and than kicks back in when cruising. I am not sure if these are related.
