Hello all,
I have a 1990 Sunbird with the 4.3 175 horsepower engine. Last year it would run fine for 20 minutes or so then gradually lose rpm's until it would barely run. I worked on it with only partial success until I had to winterize it. New parts include the coil, spark plugs, points, condensor, cap, rotor, set timing, checked an reworked many wiring connections. I even found a small leak in my fuel line. Took it out Monday and still having issues. It will run fine on the trailer for hours. Tuesday I pulled the water separator/filter, took out the fuel sender to look in tank. All looked normal. I tried to remove the fuel pickup tube from the tank but could not get it out. Any ideas?
I am also having a shift issue but not worried about that right now.
