4.3 l mercruiser one piece exhaust manifold temp senor install
kazek
Hi there crew. I acquired 19 footer monteray with 2001 4.3l mercruiser equipped with one piece exhaust manifold. Iron testing, starboard manifold was getting hot, compared to port. I cleaned the water ports as much I I could and it helped. Both manifolds were same temp ( to touch), but when I shut engine off, starboard side was hot again. I am thinking of installing temp sensors with separate gauges for each side. Where would be a best spot to drill for sensors. Also thinking of using a JB weld to attach a coupler to screw in sensors.
Q 1what is better way?
2 if drilled...which location?
Thanks in advance
Lou C
Those are prone to failure due to casting flaws, I’d get rid of them & convert to the 2 piece system before they hydrolock the engine
kazek
Thank you for responses. I would like to keep it in org state. I do realize that one piece will rust out from the inside. Just want to keep an eye before it does. Thus the question at what point. I would think....Given that all other components are in working order and maintenance is being done... temp gauge would make a good indicator of failure of the part
kazek
Does anyone has a diag or Pic where water meets exhaust
Lou C
The engine is 24 years old, and those manifolds were only made for 3 years because Mercruiser couldn’t get the wall thickness consistent so there were a lot of failures. When that happens it will let water in the cylinders which can ruin the engine. Merc & Barr both make conversion kits to convert it to the two piece. I had a similar system on my OMC Cobra and while I never had a failure I converted it to the later 2 piece style.
Scott06
Temp has nothing to do with how these fail.
they are double wall so drilling in and JB welding the bung is a fools errand . Aren’t there a few threaded ports on the manifolds already ? Another t where the cooling water comes in
Ayuh,....... It's got nothing to do with rust, those were junk the day they were brand new,......
They quit making them for a reason, core shifting, during the casting process,....
Yer idea of drilling them is even dumber than not replacing then now, before they fail, which they will do, destroying yer motor,......
kazek
I do have a spare set of 2 piece. Since one piece is junk.. where one would install temp sensor. I haven't taken manifolds out yet
Don't know what is the inside shape.
kazek
kazek
Please elaborate..... seems that ol 2 piece is preferred. Casting is pretty much simple process. Is it one ( bad mould) that constitutes for all to be bad? I get that quality of iron used may be questionable ( worked in steel heat treating)
To get a double wall casting, there are two sand cores. They would shift during the process.
You don't need a temp sensor
Lou C
If you really want to monitor temps just get an IR temp gun to leave on the boat, that’s what I do.
