4.3 l mercruiser knock at idle forward and reverse
Kikibear097
I have a 4.3 mercruiser alpha gen 2 . It is knocking and has a high pitch squeak or squeal. Need help. Was on the water at 3000 rpm heard a loud knock and oil pressure dropped. Check everything when we got home and oil is good pressure is good but on now has a knock. Any help would be great
Rick Stephens
Sounds like a rod bearing is totally toast. You may be able to pull plug wires and determine which one, but it won't matter, needs to pull motor and tear it down.
pull the drive, then run it for a bit. could be really really sloppy u-joints slapping around. (possible, however most likely the rod bearing)
if not, you need to pull the drive anyway to pull the motor
Bt Doctur
Has the sound of a loose rocker or collapsed lifter. In the first vid the knock stopped as rpm was increased. After verifying rockers and pushrods the suspect a bad rod .Pulling the spark on the offending cylinder will help identify it.
