4.3 Engine Bogs Down
numbered01
Hello, I am having this problem with my 1987 Mercusier 4.3 engine. Engine number B602338. It has the 4 barrel Rochester carb on it. The problem is the engine starts fine and idles good in the beginning. After I drive it for 10 minutes the engine starts to bog like it's starving for fuel or cutting out on me. I will run it at 3000 RPM and it wil drop to 2000 then back to 3000. It gets slower the more I have it running and when at idle speed it runs fine. I cleaned the flame arrestor and still has the problem. Today I am changing the water/fuel seperator and the filter in the carburator. I will see it that is the problem and get back to you. Is there anything else I need to check if that does not cure the problem?
Re: 4.3 Engine Bogs Down
Ayuh,... Don't Just change the fuel filter, Inspect it's contents,...
I'm guessin' you'll find water, 'n crud...
Oshkosh1
Ensign
Don't assume it's fuel related...Not saying it's not, but nonetheless, often times fuel/ignition problems can exhibit the same symptoms.
If it's been awhile since the last complete tune-up...I'd start with that.
