4.3 cylinder head crack?
I apparently forgot too drain the engine at some point and ended up with cracked exhaust manifolds and two freeze plugs popped. Upon taking the exhaust manifolds off I found these cracks in the cylinder heads. I know I have to replace the exhaust manifolds but I'm trying to determine if there are other problems. I am unsure if these cracks are new or old. One has ok written across it. The engine oil is fine.
I would pressure test the block, however usually when the head goes, the block long since cracked
Ayuh,..... Welcome Aboard,..... Could be, but I see only a tiny rust track, from the pipe plug in the 2nd picture,....
'n All cracks leak,..... if they were old, there'd be rust tracks all over,....
Rick Stephens
Typically with the 4.3L you will find cracks in the lifter galley, right above the lifters, as the first place that goes. I would actually bet money your bock is cracked.
Also, whoever built the motor did it the hard way and used automotive exhaust gaskets. They would have to be glued on to position them. The marine ones that let you install that big double wall manifold is one piece. No telling where else they short cut.
As far as I know it is a factory motor. I bought it barely used at the end of summer 2007. If the block was cracked wouldn't I have water in the oil?
Rick Stephens
Probably... how much has it run since the 'event' that pushed the core plugs out and cracked the manifolds and heads?
tpenfield
Based on 2 core plugs popped, exhaust manifolds cracked and cylinder head showing cracks, I'd say bye-bye engine :(
It hasn't run since I found this stuff so your probably right. Not what I wanted to hear obviously.
Do I look for another 4.3 or something different?
Bt Doctur
what about this
gergAlicious
I had a very similar situation recently. Both heads cracked, as well as exhaust manifolds and a core plug popped out. Sounds like I got very lucky. My block tested fine, and all is good now. Look for my thread below - 4.3 Engine Rebuild is what I believe it is titled.
HT32BSX115
Howdy,
Welcome aboard!
Well, that would be my choice unless you want a 5.0/5.7L engine in there! Since you need another block, heads, manifolds and risers, you're sort of starting with a "clean slate"......you may or may not be able to use your current drive with a V-8 depending on the ratio. (someone help me here.......a 4.3L drive ratio is something like 1.68:1?)
A 5.0/5.7L uses 1.50:1 drive I think..... the difference between 1.5 and 1.68 might be handled "OK" with a prop change only
You may have noticed that you alone called them "Freeze Plugs" and everyone else called them "CORE" plugs.
Just to be clear......Those Core plugs are there for the casting process. They are NOT related to freeze protection or anything else (other than making it easier to clear out sand and other debris during a rebuild etc)
It's possible for Core plugs to be pushed out with freezing water in the block and not have a cracked block. (I have a 454 that had a core plug out on both sides and the block wasn't cracked. It was either dumb luck for the previous owner or they were just loose to begin with!
If you just want to get another engine, look for a Chev pickup 4.3 engine of a similar year and either run it or rebuild it. You may have to swap the camshaft/lifters out of your engine to make it work best with your dist & carb..... I would probably have the valves done on the replacement engine if there was any question.
There's plenty of people here that can tell you which years to get and which to avoid.
I don't think I would waste the time to put new/rebuilt heads on a block that "might" not be cracked........... because if it IS cracked, you'll be pulling those heads off and looking for another one.
The only way to check a block for cracks is to pressure test it. If the heads are cracked, you have to put good heads (and gaskets) or some sort of blocking plates on the decks to pressure check for leaks. ANd I am not sure I would trust a machine shop to check for block cracks.......pressure checking at 15-20 psi is the best check there is!
Why waste time installing heads on a questionable block when there's thousands of them on craigslist, boat trader and wrecking yards?
Regards,
Rick
Ayuh,..... If ya go with another 4.3l, you can get by with buyin' a Long Block, 'n manifolds,......
To go to a V-8, you'll need to buy a Bobtail motor, 'n probably another drive for the right gear ratio,.....
