rozandalan
- Aug 26, 2001
- 1
Help! I am the original owner of a 1956 Lightwin. It's probably been used 200 hrs in its life and has been in dry storage for 20 years. I just took it out and easily got it to start, but can't seem to adjust the high speed jet properly. I have cleaned everything out, mixed fresh gas (1/3 pint oil with gallon of gas). At high speed, the engine smokes oil like crazy and won't run smooth. Strangely enough, when I take off the air intake and remove the little air screen just before the carb, it runs almost perfectly.<br /><br />Also, to get the engine running fast I have to set the high speed jet to the leanest setting (turned all the way clock wise).<br /><br />It idles fine and that jet is set perfectly.<br /><br />Any suggestions? I have sprayed enough carb cleaner. Also, have only let the engine run maybe 5 minutes.<br /><br />Thanks.<br /><br />Alan
