3hp Evinrude 1962 - stared running on one cylinder
I bought an used lightwin and ran it over 3 hours before the problem started. The upper cylinder fires but the lower seems to flood. There is spark to the lower cylinder but I expect it maybe out of time. At first, I thought the carburetor float might not be closing, but when I shut off the gas and drained some from it and changed the plugs, the bottom cylinder still won't fire. All suggestion appreciated. <br /><br />Does anyone know how I'd check the timing of the spark to the lower plug?
