3hp 1999 model 6L5/3MSHY Questions.
cprodave
Seems to run OK in tank without overheating. But I see no "pee stream" coming out, nor do I see any hose that would create the telltale stream. My experience on small outboards is only on OMC and Mercury. Where is pee stream supposed to come out on this Yamaha? I do see a small hose going from lower (orange pointer) to upper (green pointer) side of Engine Block (assume this is water?). What is function of item at blue pointer? What is function of item at yellow pointer?
Where is a good Exploded View (Assembly) drawing and Owners Manual or this motor? Would probably answer some/most of my questions. Thanks for any help.
