I'm having an issue with my boat and after doing some searching and reading on here I think I have found the problem but I'm looking for insight on the best fix for it. I have a 1980 16ft Lund Mr. pike with a '80 35hp Evinrude on it. The issue I'm having is when I'm at full speed (about 25mph) the front half of the boat is out of the water. The boat usually starts touching the water shortly behind the helm which is mounted right in the middle of the boat front to back(similar to a bass boat set up). It seems to me that the boat is pushing water this way and slowing me down. I have read on the here about the av plate being up to 1" above the bottom of the boat but not sure how much difference it would make moving my motor up. I don't have much room to go up as you can see on the transom. I'm wondering a. should I move it up? B. How much of a difference will it make by moving it? C. Do I need to mount a brace onto the transom so the motor sits on it and all the weight is not on the bolts?
Any help is greatly appreciated!! I have attached pics as well. In the one pic the top of the transom is at the 6" mark.
