HI I have a 35hp mercury outboard serial# a185333 all most stranded on lake last night! problem is when I turn key to start position starter drive kicks into flyhweel but motor wont turn over. But if I repeat on off on off starter and motor will turn over start and run fine.If battery dont go dead frist. It acts like cylinders are loaded with gas and motor wont pass compresstion strok problem with that is when motor starts turning over I have to choke it for it to start. It does not matter if motor is cold or hot. Does this some times but not allways. Maybe bad starter.Any ideas out there.
