I've got a 35hp 1976 Johnson that has a bad miss on the bottom cylinder. I thought I had the problem licked but it came back. If I put a timing light on it, there is no flash out of it, meaning there is no spark at all. I put in new coils, driver coil, points and condensers last month and even tested the wiring harness from the stator plate. I took the stator plate off to clean it up, too. Thanks for your info.
