35hp chrysler motor
tztop
on My boat your suppose to pull out the neutral switch to start it. then your suppose to push it in before giving it the throttle. Well now the only way My motor will start is if I pull out neutral switch and engage the throttle. I know this is no good for My engine , so could someone please give Me ideas soon ? Strippers are almost gone and I need to get out there, HELP....
jerryjerry05
Re: 35hp chrysler motor
Year? Model? Serial #
Starting procedures, pull fast idle button, then advance the throttle and turn key and push key to choke?
wickware
tztop, Does your 35hp Chrysler look like my 1970 35 hp Chrysler (55 hp cover/hood)? Our controls are different from seeing your steps.
1. I put both handles (accelerator/gear select) in the neutral position to start the engine.
2. I push-in the key to choke, turn the key to crank and release key.
3. I can accelerate slightly for cold start idling.
4. I have to be in forward or reverse before any true acceleration vs the slight rpm increase.
