Re: 35hp Chrysler cuts off
My chrysler will start up and run but once you get the boat going it runs full throttle and then all of a sudden it slows down and cuts off. I recently replaced the diaphram in the fuel pump.
Dan
Fill in the blanks.
My 19__ chrysler will start up and run. But, once you get the boat going at full throttle, after _______ minutes, the motor suddenly slows down over a time period of ________ seconds and then finally cuts off.
Also, answer these questions.
Does the boat cut off no matter what after you run full thottle for a while?
Or after you notice the motor starting to slow down, will the engine continue to run if you back off the throttle? Meaning it will only die if you keep the throttle at full throttle?
Is the primer bulb full and hard after the engine cuts off?
How do you get the motor restarted?
