35hp Chrysler bogs down in gear
Digger
I have a mid-70's 35hp, it sat for approx 20 months with the gas in, when I cleaned the carb with spray carb cleaner, I removed the mix-screw,<br />when I did, I didn't count the # of turns from seated,(I know STUPID!! ) also a small "O" ring came out of the port with the screw. This ring has square outer shoulders and one tapered inner shoulder. I have tried every setting for the screw from 1/2 turn to 2 1/2 turns, but still it will not run at high speed in gear, it starts and idles fine but bogs down when in gear and throttled up. I have installed new plugs and all new fuel lines from the tank to the carb.<br /> I need to know the positioning of the "O" ring and the # of turns out for the mix-needle.<br /> Thanx
Greg Lawrence
Re: 35hp Chrysler bogs down in gear
sounds like the idle screw is set fine. if it starts and idles. are there any other jets on that carb?
norman158
take the carb off remove the bowl and clean the main jet sounds like it might be pluged
Digger
Thanx Greg and Norman 158, <br /> I don't see any other jet or mix screw on that carb, (carb is TILLOTSON WB3A), also I have disassembled and cleaned it once, but I will go thru it again and pay particular att. to the main jet. <br /> Again thanx I will let you know how I make out
