35 johnson runs bad with cover on
dwg
I recentlt got a 77 model 35 hp johnson.with the cover off I got it running ok,but it smoked excessively,and I hard time finding the sweet spot between idle and power(carb adjusting).When I put the cover on,it went south,and fast.I just dont see where it can pull enough air to run.
rjezuit
Re: 35 johnson runs bad with cover on
In a barrel or on a moving boat?
wilde1j
Likely exhaust leaking into motor cover space from a gasket leak (adapter, exhaust cover, etc.).
F_R
There is no "power adjustment" on the carburetor. The knob is for idle mixture only. Set it for best idle and the high speed will take care of itself. That is, if everything else is as it should be.
The previous remark is right on--are you running it in a barrel? Don't expect it to run in there with the hood on, because it won't. Rest assured, it will get enough air if running on a boat on the lake. The engineers though of that. And it won't smoke so bad either.
dwg
It was in a barrel,and it sat for a while i went ahead and ordered a carb kit and exhaust gasket.Will I need anything else for the exhaust job?Parts wise.
restornator
a lot of members recommend using a fan to blow away the exhaust while running in a barrel
dwg
when i rebuild this carb is there anything i should do different or know about,vesus a car or brigs,ive built alot of carbs just not a boat.
jeff_smith_0423
Get a service manual for your exact model before attempting the carb rebuilt unless you've rebuilt 2 stroke carbs before. They're not hard but they're not like an automotive carb.
