35 Honda, no spark @ # 1
Bill53
Hi, I have amid 90s 35 honda on my pontoon. #1 cyl has no spark! I have changed plugs, switched the coil with #2 and switched the plug cap with another. Still no spark on # 1 .
Any Ideas what to do next ?
Regards Bill
hondon
Re: 35 Honda, no spark @ # 1
This is a very unique ignition system.To my recollection # 1 operates from the sensor under the cam pulley while 2 and 3 rely on the tradtional flywheel.Ignition failures are rare so make sure that you are not throwing ignition parts at a carb issue.
Bill53
Hi, Thanks for the info, is there a way to check the cam sensor ?Regards Bill
Bill53
Thanks Hondon, You were correct , it was a carb problem.
Regards Bill
marquette
what were the symptoms that made you think you had a problem?
Bill53
The honda was running along at low rpm and it started missing
