I've so far put a waterpump, thermostat, and head gasket on this motor, flushed out the pipes and channels with water raised the water in the tank and thought it was fine. Tried running it with muffs and water seemed ok, put it in a bucket and wasen,t sure because this model does not have a tell tale.Thought it was ok took boat to water this morning and it still fried. When I took the head to the shop the mechanic said it was slightly warped in the middle but should be ok by tightening middle bolts first.Took leg of after our fishing non adventure and put hose on pickup tube and turn on water. The water was leaking out of the exhaust side cover and filled the bottom cylinder with water. Could the side cover cause this problem or would it be somthing else. I,ve spent hundreds on this motor and am almost out of ideas and close to broke. So any info would be great.<br />Thanks <br /><br />Griffo.
