Re: 33hp evinrude
Don't just bolt down the head. It's got to be surfaced and checked for warp like rodbolt said. Also, you need to torque those bolts properly in the correct order or it's just going to blow again. That's why the manual is important - it shows you how to do all that stuff.<br /><br />If the engine reved up to scary RPMS and then quit never to restart again, then check for spark. I think there's a chance the flywheel key sheared, and if it did then engine will have a very weak spark or none at all. You do not need to have the head or the spark plugs in place to check for spark - just plug in a spark plug, lay it against the block and pull. <br />Now why the engine did that is another question. Start by putting the engine in gear and turning the propeller. Does the engine turn with the propeller? Or is it slipping?<br /><br />If you don't know for a fact that that water pump has been replaced in the last year or two, it's time to change it too. Again, the manual will show you how.
