Re: 33hp electric start
Yes it will. <br /><br />Make sure you've got all the stuff you need though. You need a flywheel that's got teeth on it. You also need a bracket that comes off the block and holds the starter. If it's one of the later "Prestolite" starters there will be an additional bracket for the bottom of it. You will need an outboard solenoid (explosion-proof), some wiring, and an ignition switch.<br /><br />If you want to go full-remotes, you'll also need an electric-choke carburetor.<br /><br />Those starters, brackets, etc, should be as common as dirt. Check out the local junkyards first. Usually at worst, they will need a new set of brushes.
