33 hp block
Woodstock60
I have a 1968 33 evinrude. while stripping parts off a 1955, 25 hp johnson I noticed the block was the same. I cant find info on the 1955. Does anyone know what the differances in the blocks are. The 33 has a fair amount of damage where she bolts to the exhaust housing. Was thinking I could either swap out as is or rebuild with good block. Any advice would be appreciated, Thanks, Ronnie
F_R
Re: 33 hp block
Oh they look similar, but actually there are a lot of differences. In the first place, the 25 is 2-7/8" bore and the 33 is 3-1/16" bore. They have different bearings, cylinder heads, crankshafts, and flywheels. And more..
Just an interesting tid-bit of info on the 25: They made a mid-year change in 1955, "improving" it to the point that they created a lemon. An awful lot of powerheads got replaced under warranty that year. In the 1956 30hp, they "un-improved" it back to the way it was in the early '55s.
Woodstock60
Re: 33 hp block
Thanks, That makes my desition easy, I'll stick with what I have on my 33 and keep the 25 for parts for my other 25. I am curious what was the mid year change? I have a running 1955, 25 seahorse, which has had its share of issues and I'd like to find out what makes it junk, and if mine has these changes. Thanks Ronnie
F_R
Re: 33 hp block
Early models had a carbon seal on the bottom main bearing. Then somebody decided that was too expensive so they changed it to a common lip-type seal, part number 303804. The 303804 was a crappy seal and was lucky if it lasted a year. When it failed, water was ingested into the lower main bearing and circulated throughout the powerhead, totally destroying it. Wonder if that genius that made the change got a bonus for saving the company money? Anyhoo, they went back to the carbon seal after replacing a bunch of powerheads. To retrofit an existing 303804 requires a different crankshaft and main bearing.
Same goof-up was made on the 15hp (picture)
Woodstock60
Re: 33 hp block
Thanks for that info F_R. It looks like mine has the carbon seal, I certainly hope it does. I'm going to start a new thread on this motor and post some progress pics. again thanks
Minnow00
Re: 33 hp block
F_R do you know if the part number on the carbon seal is the same as the part number for the lip-type seal? My parts catalog shows part number 303804 for my FD-10L sn1407586
