Due to deteriorating insulation, I spent the afternoon replacing a good portion of the wiring on my motor. In the process, I had to replace the in-line fuse holder. Since I already had one, I used it. The original used a short glass fuse which was 20amp, 32 volt. The one I used takes the 1.25" glass fuses. Since I have a bunch of 20 amp, 250 volt fuses which fit, does the voltage matter or should I seek a 32 volt fuse?
