Hi, I'm looking for some advise for a surging issue. I recently rebuilt the carb and replaced the fuel pump, gas tank ( with fresh fuel) and fuel line to my 1985 Mariner 30 hp. The engine idles well and runs fine until about 3/4 throttle then it starts to surge. Tank is the new EPA regulated non vent screw type. There's a vacuum build up that i understand is normal. I've cracked open the cap to prevent that but the boat still has the same problem. Could this be a vacuum problem somewhere in the system or perhaps an improperly adjusted high speed mixture setting?
Thanks in advance for your advice
Steve
Steve
