30 years and I finally joined the plug club, as a double
gypsysoul
I knew this day was coming, I had hoped I would have delayed it longer though. Thursday after setting camp up at our lake. I decided to launch the Sea Doo's. before the season had started, I serviced the ski's at the house. this included pulling the pumps on both and installing new bearing's and shaft seals. so while I had them apart, I decided to clean inside the hulls. So I pulled the PLUGS. After cleaning, I left the plugs out to let all the water drain out. Well you guessed it. I backed down the beach in front of camp and slid the ski's in. anchored them and pulled the truck out and parked it. when I walked back around the camper I noticed the ski's sitting pretty low in the water. That is when the light bulb over my head lit up. I had to run down drag the ski's up on the beach and let them drain. one was ok, one had to have a little cpr before it lived. So not only did I join the drain plug club. I did it as a double. So does that mean I am good for sixty years now? :D:D:D
jonesg
Re: 30 years and I finally joined the plug club, as a double
Due to the time lapsed it might classify as senile human trick.:D
kend301
Do not mean to hurt your feelings but my take on the time line is 30 years , 2 boats at once , divide by 2 = 15 years. You also said "plugs" .. 2 plugs per boat =4 so divide by 4 and that is 3 years 271 days . That is per boat so divide by 2 again and that leaves 1 year and 317 days. Since most people launch once a week that leaves 97 days. Now for the age factor , divided by your posted age = 2 days , 2hrs and 40 minutes. Divide again by number of years over 40 due to the I never make mistakes syndrome = 8 hrs and 24 minutes. Since you have lasted 30 years and should have lasted only 8 hrs divide by 32850 ( the number of hours you have cheated this fate ) gives you less than a second .
Sorry to inform you your safe time has expired . ;)
gypsysoul
my abbaca's are smoking, but I believe that you are correct!:eek:
itsaboattime
uuuuhhhhhh yeah.................what he said!!!:)
Thad
This is one of the funniest things I have read yet!!!!!!
I love it.:D:D:D:D:D:
