Re: 30 hp merc. stalls
Ask a dealer or get a manual to get the float height, I don't have info for that engine. You'll need to pull the carbs, turn upside down, remove bowl, and measure from carb body to top of float. Bend the float arm at the needle valve to change the float height. Since it's a 95 you may want to replace the needle valve while you're in there. Get a gasket set also, they're cheap. Don't buy a float unless you're independently wealthy.
