30 horse fuel issue
ironsetr
This is my problem when i try to go full throttle my engine starts to miss like it is starving for fuel. it will idle all day when i hand line i can run 3/4 speed no problem it is just when i try to open it up all the way is when the problem occurs. also if i crank the handle to full throttle out of the hole it will miss unless i back it down and it takes me longer to get on plane any suggestions anyone is the fuel pump going bad?
fireman57
Re: 30 horse fuel issue
The way to check your fuel pump is when it starts to miss or won't get to top end is to squeeze your primer bulb a few times. This overrides the fuel pump. My bet is you have dirt in your carbs.
kenmyfam
Fuel restriction most likely it is just a matter of where. As said try squeezing the primer bulb and see if it picks up. If not give the carbs a service.
ironsetr
thanks for the replies very helpful once i get the shrink wrap off and the ice quits coming down the river i will give it a try but i think i will give carb a good cleaning before i dump it in also i almost forgot i did run sea foam thru it last year but did not help it
