While changing the impeller on my Yamaha 30 ELRZ, the lower end slipped from my hand. While trying to catch it, I broke the shift cam rod. I was able to remove the plastic bracket adn rubber boot from around the shift cam rod which allowed me to pull the rod with the steel triangular thing (cam follower??) attached completely out. I'll have to purchase a new rod and boot, but how do I install it properly? Hopefully, I don't have to totally disassemble the gearbox (prop shaft, bearings, etc.)? Pictures are attached.
Thanks - Mike
Thanks - Mike
