Hello,
I just swapped out my dual 86 V4 140 Johnson's for a single 1999 225 Evinrude. In hooking up the motor, I've got the motor mounted T&T switch working, but I can't get the one on the dash to work. It worked before on the 86's. The dash switch is a 3 wire setup. I'm confused...what am I doing wrong? Will a three wire dash switch work on a two wire T&T? If so, why will one work and not the other. I look forward to any help. I'm learning a great deal from all of you...thanks for that.
Duke1
PS-Batteries good...just cleaned and tightened connections.
Duke1
