I have a 1978 35 evinrude I did a spark test and all 3 cylinders are dead on the right bank Cylinders 2,4,& 6. I was wondering if anybody knows how to test the power pack. I tested the timer base and that is fine. It also appears the volt meter is not going above 13 volts where as before it was around 15 or 16 while running. I wouldn't think all 3 coil packs would go bad at once. Any help would be appreciated thanks
