Re: 3 cylinder stacker!
ANYONE can do it the "redneck" way but if you do it right, you will really have something
If you are careful with porting and port both bypass and exhaust, then you can expect about 5-10 horsepower gain per cylinder. These gains come at higher RPM so you need a 2 to 1 lower unit and a slightly smaller diameter but higher pitched prop. Your 75 has small exhaust ports timed differently than the 85-90 so if you do square them, to realize maximum gains you must also elongate and enlarge them. See if you can't get your hands on a junk 85 block to compare ports.
Because the exhaust ports open for about 120 degrees and the crankthrows are 120 degrees apart, there is no open overlap and it is not necessary to isolate each cylinder using stacks. Although, if you do use them and "tune" them you will gain additional horsepower. If you do your homework, (which I never wanted to do) You can compute the correct length for the pipes AND unless you want the noise, you can design the pipes with a smaller outlet which will muffle noise and reflect the pressure wave back to the ports. Of course, if this is your goal, then you must isolate each cylinder. Older four cylinder racing Chryslers had two open pipes tuned to reflect pressure waves back to adjacent cylinders which fired 180 degrees apart. A special water cooled exhaust manifold was used.
If your Chrysler is an older one with a two piece lower unit, you will gain about 3 MPH by mounting the powerhead on the newer Chrysler or Force one piece midleg and lower unit.
Again, if you have an older Chrysler and speed is one of your goals, then swap out the stock ignition for Mercury electronic-- It's a lot like building a custom hot rod: Find the parts and adapt them to your engine.
Remember that inside the exhaust cover there is a stainless steel plate and it always warps with heat. Your pipes must also pass through this plate while still sealing water into the cover.
So again, if you absolutely want pipes, you must do the research. But after that comes the fun. And you won't believe the noise. Neither will your neighbors.
