Re: 3 cyl. outboard issue
3 cyl w/ twin carbs, the mounting plate has a open passage behind the carbs so all cyls draw off of all carbs.
The actual airflow pattern is the top cyl draws most all its air from the top carb, the center cyl draws mostly equallly from both carbs, and the bottom draws mostlly from the bottom carb. The path of least resistance thing.
This is why is it absolutely critical that the carbs are 'synched' correctly. if either carb is even slightly open at idle, then most all air is drawn thru that carb.
I suspect that your top carb is slightly ajar/open, just only a hair, and the bottom is closed.
You can 'feel'' the airflow thru the upper and virtually nothing thru the lower.
Timing. The triggers are spaced 'equally around the trigger ring. Each gets 'triggered' by a magnet in the hub of the flywheel. If one trigger coil is misplaced during manufacture then the timing for that cyl will be 'off' by however how many degrees the coil is misplaced. It may be either advanced or retarded up to three degrees depending on how wore out the mold is and how observant the operator was. Usually this isn't a big problem but on some motors it can make a big difference.
My money is still on your carb synch. Critical for idle, but once throttle is opened no longer a problem.
