My 1985 Evinrude 40 has two holes in the air silencer to adjust the low-speed needle valve is this common practice?
My engine only will stay running at idle and on muffs with a push every so often for the primer solenoid.
What's the best way to adjust the needle valve to the proper setting?
I recently purchased the engine and just found valves to be in the closed position. I tried to adjust them to keep the engine running, half turn at a time up to two turns counterclockwise but it didn't help.
I figure I'm looking at having to rebuild the carbs Whats the best manual for the job? And am I right?
I've installed a new fuel pump and there are no fuel leaks, everythings tight.
Fish from Shore
Fish from Shore
