fordmechanic#1
- Oct 4, 2003
- 22
Hey there. I have a 3.9 hp merc. The serial # 2375578. The engine will start and run for about a min and then it will die. It just goes burrrrr stop. You can start it back up does the same thing. I have tore the carb apart cleaned it. Changed the fuel line it had a crack. I changed the crankcase hose going to the fuel pump. It does the same exact thing. I have tried choking it when it is gonna die i have tried pumping the bulb and still a lost cause. Any help would gladly be appriciated. Thanks
