3.7 mercruiser 170hp rebuild
scott10732
Anyone rebuilt a(470) 1987 serial number b485553 3.7 mercruiser 170hp, And if so what kit did you use and were did you buy it. Thanks
stonyloam
Re: 3.7 mercruiser 170hp rebuild
You would be wise to not use the auto head gasket that comes in a kit. Spend the bucks for an OEM Mercruiser HG. I would also go with OEM cam waterpump seals, and crank oil seal.
500dollar744ti
Do they really put auto head gaskets in those kits? If the motor never saw use in a car, why would they ever do that? I know it's a 460 head but that makes no difference because the engine kit should be designed for a boat.
achris
More fish than mountain goat
They can use an automotive head gasket because the engine is freshwater/AF cooled.... No salt-water in the engine internals....
stonyloam
Chris is exactly right. The auto head gasket is designed for use in an engine with a iron head and block, not the Al block of a 470. The OEM gasket was designed with some extra sealing features. I do know that the guys that hot rod the 470 (including a land speed racer) say the OEM head gasket holds up much better.
blkzoe
Rebuilt a 170hp 3.7 over the past winter. Not a difficult job, but take your time and employ quality parts. Make sure you check the head for cracks when having the valves re-ground and re-seated. New valve stem seals a must. Get the permatex aviation sealant #3 for your gasket work, great stuff. Oil pump alignment via distributer shaft is a big must; don't screw this up.
See here for the parts source I employed: 3.7L | Engine System. | Mercruiser | Basic Power
OEM gaskets are more expensive, but consider the cost of re-doing the engine in $, time, and bile.
stonyloam
Speaking of heads, when I had mine done had hardened exhaust seats put in. As I recall it was not that expensive.
