Re: 3.7 engine swap
There are differant kinds of pumps for the engine but I am not sure if it matters witch one you have. You would have to look up the specs. I know there are two differant arms and one the goes upside down as well, but beleive all forms of this engine require the same fuel pressure.
Mine has that same glob, but i see it through the top side under the carb, it may have something to do with the casting. I know when I worked in a foundry we had castings that would leave holes on them and I would have to weld them to close it. Thats my thought of it any way.
It will be hard to find a crack if its small, you will need a die that is sold that you cot the area with and it will seep into the crack so you can see it.
Throw that other manifold on and let us know what you get.
