3.5 Isuzu trooper towing at 4000 rpm
bonitoman
When I tow my 4000 lb boat down the highway in 3 instead of overdrive, I notice that the rpm's are 4000 and the engine sounds like it is working hard. Is the rpm range to high to tow for a three hour period on the highway at 4000.
jlinder
Re: 3.5 Isuzu trooper towing at 4000 rpm
I would not like to run at 4000 RPM for that long. I have a 2001 Isuzu trooper, 3.5L and 4000 pounds to tow, exactly like you.<br /><br />Just curious, are you keeping it in 3 because you had a problem? What speed are you doing with 4000 RPMs in 3rd gear?<br /><br />I run in drive and let the transmission handle the shifting. The most I do is when it gets hilly I select power drive, which changes the shift points (lowers them).<br /><br />I have run for 3 hours or more with no problems. RPMs are fine, and there is a lot of power.<br /><br />The only thing I have done is step up the schedule for transimssion filter and fluid change. I did a change at 50K miles and it shows the fluid was due for a change. I will probably move to every 40K miles for the next ones.<br /><br />Love the Isuzu for towing. Would like a little bigger engine, but not a big deal.<br /><br />Just let the transmission do it's thing and shift for you.
gutshot grouper
Slow down, you did not say what the road speed is at 4000 rpm, but i would not run it for long at that high speed, unless you plan to replace it shortly.
PeteHarris
Jack L ... if the fluid looked like it needed to be changed (dark, smell of toast, "stuff" in the filter) then you have already damaged your tranny.
hookless
I have a 2002 trooper and I tow at 60-65 in 3 and the tach also reads 4000 rpm. I was told by the dealer to not use D since that is overdrive. I did use D one time and the tranny was shifting constantly between 60 -70- mph.
jlinder
PeteHarris - the fluid did not have the symptoms you talked about, but I was told it was just starting to show some change. Mechanic doubted there was any problem - caught it early enough.<br /><br />hookless - I have not had the problem with it shifting all the time, and I run in D. Have you tried the power drive setting?
hookless
I have never tried the power drive setting. Would you tow on interstated 95 in florida on power drive in D
jlinder
That is pretty flat and I have been towing with the normal setting where I live and it is also pretty flat.<br /><br />I have used power shift and normal, and on flat roads find very little difference. Power shift helps on the hills though.<br /><br />I would give it a try.
tomatolord
normally the rule of thumb is D and if the transmission is "hunting" shifting up and down then shift to 3 until you can shift back to D
jlinder
I agree. The reason I leave it in D is that I very seldom experience hunting. <br /><br />It can happen a little up a hill, but I select power shift and the hunting goes away (typically the transmission also goes to 3rd gear)
Nos4r2
I'm so glad my trooper's a turbo diesel stickshift reading that...I just get in it and drive...
