3.3 HP OMC
m1rodrig
I just came into possesion of a 3.3 HP OMC Model # HJ3RENR Serial # H9274137 Made in Hong Kong.<br />I don't know what year it is but was hoping somebody knew what is the mixture & where I may be able to find a manual for this engine.Thanks in advance for your help.
JB
Re: 3.3 HP OMC
Howdy, M1rodrig.<br /><br />I think you have a 1992 Johnson 3hp.<br /><br />H= I dunno :confused: <br />J= Johnson.<br />3= 3hp.<br />R= rope start.<br />EN= 92, from the code using "introduces" for 1234567890<br />R= production run.<br /><br />Good luck. :)
Paul Moir
Re: 3.3 HP OMC
Welcome, mlrodrig.<br /><br />H = Hongkong<br /><br />(CLIP)<br /><br />EDIT: Got the rest from JB, oh, except this:<br /><br />The correct fuel/oil ratio would be 50:1 87 octane to TCW-III outboard oil.<br /><br />Good luck!
m1rodrig
Re: 3.3 HP OMC
Thank you both for your help i am going to go ahead & try to start it up tommorrow so i can take my son for a ride in the lake, he is 3 & he is really excited i wanted to make sure i knew proper mixture before starting.
m1rodrig
Re: 3.3 HP OMC
Well I tried to start it and had no luck the only way it would start was to pour gas down the carburator & then it would only start for 1 1/2 second. I took the carburator off.The float chamber was full of junk so i cleaned it out the best i could & closed it back up when i opened the fuel it started right up but then flooded. The gas kept flowing from the inlet. I reopened it & I must have lost the needle that shuts off flow from fuel inlet when i took it apart.I got a manual but it is a 93 manual.Ordered the carb kit & just got it i will build it this weekend. Manual says 1100 to 1300 RPM. How do iknow what RPM i am at , do I need a gauge? How do i set the idle if i dont have a gauge. Thanks for the help with the year and make I would have never figured it out.
