olddogmike
- May 25, 2003
- 39
I have a 3.0 LX mercruiser inlione 4 cyl with a Alpha 1 outdrive unit. The boat will make way up about 2000 rpm, after that the rpm's go up and speed falls off. The wheel hub is brand new. I don't smell rubber burning but I have never let the engine continue to run after the rpm's begin to climb. I was told that it sounds like the engine coupler so I pulled the engine and flywheel cover and removed the coupler. It is a triangle coupler for a 12 and 1/2 inch flywheel. I will be ordering the new coupler on Monday. The thing that is bothering me is that the old coupler does not look to be damaged. There appears to be no visible rubber damage. If this turns out to not be the coupler then where should I look next for this problem? Thanks to all on the board for any help you could give me.
